eMotion LV1 requests
Hello, i’m pretty new to LV-1 but have some functional desires already. here’s my list (until now)
  • Easier programatic access to desk functions. eg: bypassing a rack plugin. Preferable via multiple protocols like MIDI and OSC (or as said before: grant OSC/MIDI access to all functions available to the assignable buttons)
  • Possibility to send a “hard state” to such controls, like “put rack plugin4 of channel 12 on bypass/enabled”.
  • Better documentation of available remote control interface. Like a midi-map, etc.
  • The possibility to make the TALK button latching.
  • Internal routing, make it possible to use outputs as channel input.
  • Color: I would love to have the possibility to color-mark my faders/channels
  • The possibility to use custom layers for the MyMon app.
  • some feedback from development team/product owner about the suggestions mentioned on this page.
Thank you!
Keep up the good work of developing this wonderful console!
Hi Steven
You can already make the talk button latching by going to the talk setup and hold the big talk button
You can assign Colors to the strip by selecting the channel and going to Preset>set channel color
And you have access to the custom layers on the MyFOH app
Good day :slight_smile:
THNX!
Pointing me to the color-select helps a lot.
The latching of the talk button acts a little strange. as soon as I activate it the TB mic indeed stays on. but if I push us user-assignable button (linked to the TALK command), the TB mic switches off, but also back to non-latching mode.
The fact that the custom layers are available on the MyFOH app, does not really help. I want to setup a custom layer for the musicians so they have all instruments and the monitoring-reverb in a single view.
They use the MyMon app, and that seems to be capable of displaying the full mixer lay-out only.
BR, Steven
From the users phone/mymon app, press the MIX button (it has an eye symbol). From there, the user gets the option to pick what they want to see via the green check marks. Can hide all channels, and then just pick the ones you want to see. It has nothing to do with what you are doing at the console level.
LV1 > Superrack converter
LV1 remote for superrack like digico console
Multiple servers working like Superrck
Hi there!
I recently implemented a LV1 setup in a corporate broadcast studio, and it’s working great BUT -
When they do very small webcasts there it would be very beneficial to be able to use a Streamdeck/Companion and control for instance mutes on the mics from a separate computer. So if Waves could develop a “Connection” for Bitfocus Companion, I know that I and many others would be extremely thankful!! :slightly_smiling_face:
Basic AuxFX SEND Master Fader control. We currently have to run an FX channel INTO another FX in effect limiting the useable AuxFX mixes to 4 instead of the listed 8. There is a Trim, but it doesn’t occur on the fader page and therefore takes too long to access. Shouldn’t take much to put the Trim as an FX Master Send.
Multi-touch for mac osx.
Yes the drivers exist. And work great.
Simple latch talkback mic.
Add presets to talkback for Ability to send talkback mic to certain monitors only.
Need assignable dca’s for any assignable adjustable perameter, maybe dca knobs, one knob can be assigned all vocals compressor thresholds for example instead of driving all vocals into a single bus compressor.
AND see post fader meter at the same time as input fader.
In MyMon, I’d love to be able to hide and re-order the channels that are shown in the MyMon app. I’d like to do that from the LV1 and save that to the show. The musicians only need about 20 of the 60 channels I’m using, but they need to search through them all to find the ones they want. As things get added and removed, the channels start to fragment, similar instruments and vocalists are no longer grouped next to each other which makes finding things more difficult. I use custom layers to deal with that problem at front of house, but that is not available on MyMon.
MyMon doesn’t even display the channel numbers. At least if it did that I could tell them the number of the channel their looking for, that would make things easier.
Displaying the colors in MyMon would be nice too.
my LV1 wish list
FIT - push rotary pan/gain encoders to select channel. as far as I can tell, this button has no use in LV1.
FIT - touch n’ turn - option for push to select master channel instead of plugin parameter on/off.
^ these two would speed up navigation greatly for those of us who prefer to interact with the surface vs selecting the channel on the screen. without having to leave User or Flip mode.
FIT - touch n’ turn - encoder resolution controls. Currently too slow/high resolution to be very useful. “Press to increase encoder resolution.” is mentioned in manual but seems to have no effect.
Prev/Next channel shortcut, and arrows in color picker - follow channel order of Custom layer when on custom layer.
Color picker window- allow channel renaming
A fully assignable MIDI controller section, like in SuperRack
Server load shown as percentage, like in SuperRack
Scene crossfades, at least the faders.
SHOW MODE. lock out all network settings, plugin instantiation, any setting that can stop audio.
  • Ability to change pages in Flip Mode without having to reselect the aux and put it in flip mode.
  • Send FX to groups
  • Ability to control aux send via Link (for things like delay throws)
    FIT - option for push to select master channel instead of plugin parameter on/off.
Visual feedback for buttons in Show window. Especially “Save” session, and “Store” show, just blink the button or something, like user buttons do. I always push it a couple times because there’s no indication if I hit that important button correctly.
Now that v14 is out, here is my running list of requests. It’s exactly the same as the last two years except the ability to add multiple servers was added. I wish the developers would start listening more to their users. These requests are pretty common and have been asked for for a long time. At $2000 for the 64 channel version, the LV1 is not a cheap system once you invest another $8000+ in the hardware infrastructure to make it all work. I’m starting to get frustrated that i’ve invested as much money as I have on software and hardware only to have LV1 treated as a what feels like a side project. I like the LV1 platform. I’ve been a Waves customer for 20 years and I renew my update plan every year but I’ve got to be honest, it’s getting harder and harder to fly the flag with every release.
  • Label talkback presets
  • Label Mute Groups
  • Allow CUE to be an input to the matrix (Done. Added in v13)
  • Rename user Define Key Labels
  • Scene Crossfades
  • Multiple SoundGrid Processing Servers (Done. Added in v14)
  • Assign FX to Groups
  • Option to have the mutes and faders on the FX busses control the input rather than the output so I don’t have to burn a monitor bus to do delay throws
  • Similar to EQ and dynamics, designate certain plugins as Effects and make that a selectable option in scene scope and recall safe
  • Allow direct midi or keyboard shortcuts to all functions that can be assigned to user define keys
New request for this year:
  • Allow MyFOH app to control all the functions of the default EMO F2, and D5 plugins. Looks like Q4 is taken care of in the latest version of the app.
V14 multi Server is great and we definitely need that.
I still have a desperate list that is very frustrating.
LV1 needs 16 Groups
LV1 needs 32 Fx Channels
Ability to name Talkback buttons
Ability to name Function Buttons
MyMon should already display the Chan Colors
MyMon needs at least 10 preset buttons if not up to 15
MyMon needs 12 link faders at least!
3 mixer tab’s Please
Ability to connect 3 Fit controllers
A new FIT extender 16 channel fader to sit beside current Fit controller.
Support for Clarity VX Pro!!!
  • Additional patch point for aux sends pre fader and from the middle of the plugin rack. Ideally it would be selectable from anywhere in the plugin rack.(Would make it possible to have just some plugins affect the monitor send and others not. It would help in not having to make separate monitor channels, and would speed up the workflow when mixing monitors from front of house.)
  • Input metering on FIT( Maybe it would be possible to add small meters to the channel displays of the FIT)
Another year and continuing my annual LV1 request list. Below is my running list. Let’s hope v15 knocks a few more off the list.
  • Label talkback presets (I like that you can now see the the names assigned to busses but I still want to label the presets such as talk to band, drum tech, artist, band and artist, everybody, etc.)
  • Label Mute Groups
  • Scene Crossfades
  • Multiple SoundGrid Processing Servers* (Done. Added in v14)
  • Option to have the mutes and faders on the FX busses control the input rather than the output so I don’t have to burn a monitor bus to do delay throws (Done in v14.26.85.702)
New request for this year [2023]:
  • Allow MyFOH app to control all the functions of the default EMO F2, and D5 plugins. (We got MixMirror this year which is basically VPN and I’m fine with that. It’s locked to the LV1 software so you can’t accidentally end up in a file explorer window.)
I second most of the list from @houghton.cb . I’d like to add:
  • IMO there is no real adequate screen mode for use with the FIT: either you see the faders twice (on the FIT and on the screen), or you don’t have any VUs, e.g. there could be a small (fader?) bank including VUs and gain reductions in the bottom 10% of the screen, also when in channel view. This would also allow quicker channel selecting when running on a single screen only (also w/o FIT)
  • a bigger screen button for return from plugin-view to channel-overview (i often miss this small arrow at the top)
  • view of the channel should IMHO stick on the same plugin (or same view) when selecting a different channel, e.g. when in channel 5 and editing plugin 3, and then selecting channel 6, it should be at plugin 3 again
  • i somehow miss something like the right column in Superrack with the hot buttons and user buttons, such a bar should also be accessible in LV1 all the time, at least in channel view and mixer view
  • user buttons in mixer view should be bigger IMHO
  • more than one mode on a 2nd or 3rd display, e.g. mixer2 + show window + channel view on the second screen (no need for drag’n drop, a simple setup option would be fine)
  • a “select master channel” on the FIT
  • flipping on the FIT appears to be very slow, spilling even more
  • maybe a bit more logging of the health of network and cpu (load/heat) of server and host (e.g. server cpu lpad and temperature over time)
  • a small FOH i/o (basically a Digigrid-D in 1HE 9.5-inch besides a proton duo below a FIT).
  • a FIT with VU meters …
OSC please, this will open up avenues into broadcast, theatre and 3rd party control like panLab Console.
  • Would be great to have metering on the Link groups. Would be great if it would work like the metering on groups. Makes it much easier to keep a good overview of what’s going on.
  • Little red mute square on the bottom of the mini meters on the right of the Ui. Would be great to have a quick overview of what is muted and what is not.
  • Metering on the Fit controller. Maybe it is possible to implement little meters on the oled-s of the FIT? Would be of great help.
  • Implement a very short fade when muting the signal. There is an audible crack when a channel with signal going through it is muted. Maybe a very short fade would fix it.
  • Implement more plugins in the channel EQ and Dynamics sections. For example the first one should be to make the F6 show up in the EQ section.
  • Improve the responsiveness of the UI and the meters. The UI feels like it’s running at a quite slow refresh rate. If I run the same plugins in my daw, they feel much more responsive. Would be great, if the whole UI of the LV1 would feel snappier. Especially the layer change with the FIT. I know that the FIT and the midi protocol is not the bottleneck, as the FIT can be incredibly snappy when used with mixing station in LV1 mode.
