First of all, your host application, Audacity, is not officially supported by Waves. Check out our list of supported hosts.
This does not mean it will not work, however, just that we did not test or qualify it.
x86 is the 32 bit file structure that Waves is installed to, but, our plugins all work in 64bit format and 64bit hosts.
I would suggest checking which versions you have licenses for and installing each product via Waves central in the corresponding software version.
If you own a host application that we do support - I suggest you contact tech support to sort it out there.
Hey there , I’m all good , I did the roll back to VERSION 10 for my plugs ins and then I stuffed everything inside the Plugins Folder for AUDACITY , I’m back in business.
When the DAW Scanned it eventfully made the connection to what it needed lol.
