Hi folks, I was having an issue where my machine was constantly hitting the red line on the waves superack. My machine is fairly new but it would continue to clip and pop the audio. I found that superack was using both the efficiency cores and the high performance cores. I installed Lasso and forced the machine to use the high performance cores only, along with using high power settings, and installed a small AIO water cooling CPU cooling fan, and the clips and pops have gone away. Running the system now at 96k 128 buffer size with no issues using an SQ6.
I hope this helps the community.
