I just got Waves Harmony and am wondering how to set it up so it reads the midi notes of a synth track that I already have recorded. My hope is to do a vocal track with it reading the notes of that particular synth midi track. Is this possible? Also, if this is possible, do I still need to set the key of the overall track?? Thank you in advance for any help on this matter.
Hi @hallco,
This should be possible by following the steps below :
- Insert Waves Harmony on a vocal track in your DAW.
- Create a new MIDI track in your DAW and route it to Waves Harmony. If the Harmony virtual keyboard is mirroring
your MIDI keyboard, you’re good to go. If you don’t know how connect a MIDI channel to an audio plugin, or if you
are having trouble, refer to this Waves Tech article.
We suggest that you start by selecting the correct Key and Scale to match
your session. This ensures that the created harmonies suit the song.
6 Waves Harmony / User Guide - Play MIDI notes from your keyboard, along with the vocal track in the DAW. Each played MIDI note appears on the
virtual keyboard. You will hear the resulting harmony playing along with the source. - Use the Notes panel (left side) to further control each harmony.
If you need any further help or information feel free to reach our Technical Support Team.
Unfortunately the way Logic works with passing MDI to audio plugins is quite antiquated and less than ideal. Hopefully they’ll change that in the near future, but until then following the steps above is the way to do it.
Great I will try this out. Thanks for the help.
Hi there. I would like to trigger the harmonies directly from midi notes already existing in the midi track without having to actually press any keys on the midi keyboard. Is this possible?
Yes it should be. Although how you set it up varies a little from DAW to DAW.
Logic requires that you set it up as a Midi-Controlled Effect, which is alot like setting up a plugin like a virtual instrument. The actual audio has to be passed to it as a sidchain which is a little annoying, though. But set up in this way Logic will then track and use all incoming midi, whether it be live or recorded to track.
Other DAWs will be different.
Hi! How exactly would you do this sidechain? I can’t find any option directly in the plugin.
As I wrote above…
Once you do this the side chain option will come available in the top right where you select the audio track to be passed to Harmony
…set up in this way Logic will then track and use all incoming midi, whether it be live or recorded to track.
Make sure that Generate Notes is off too.
