Hi, I notice that most of your Signature drum plugins have buttons to select which drum instrument to process. So from that, I deduce it’s intended that one instance of the plugin be placed on each instrument track. Correct ? To me, that seems like it would cause excessive CPU usage. Comments ? Feedback ? Thanx !
Hi @myacct7
Thanks for joining our forum.
I think nowadays CPU processors are capable of handling a Waves artist signature instance on each drum track. If it’s overloading the CPU, you can obviously freeze the instrument, increase the buffer size, or print it to an audio track.
Modern CPUs are pretty powerful
I take advantage of freezing quite a lot personally. I find it preferable to bouncing as the process is more easily reversible. That makes workflows more efficient and my CPU can relax a little.
I say a little as I always end up punishing it in the end anyway. ![]()
Man I need a new computer, ![]()
