Quick Uninstall for Demo Plugins!
I can’t believe WAVES makes us uninstall ALL OF OUR PLUGINS just so we can removed the DEMO plugins. This is so unprofessional. It is hard to believe that if you test a large bundle, your two options are 1.) Delete EACH plugin BY HAND or REMOVE ALL PLUGINS just to get the demos off of your rig. COME ON WAVES! I own thousands of dollars of your plugins. Please fix this soon regardless of whether a single person votes it up.
Yeah this is still a pretty annoying oversight. Though, from what I can tell from the last 5 or so years, Waves Central is under constant improvement, receiving updates quite regularly.
I would say that since this seems to be a pretty popular request they will most likely have it as part of their roadmap updates, I just can’t tell you when it’s likely to be added. Most recently they’ve been working on V16 compatibility plus stability and performance improvements.
Perhaps we might see it in the next 3 to 6 months??
This. One of those basic things that should have been possible from the beginning.
You can actually go into the Waves folder inside Applications/Programs and delete the plugins manually from there. You’d have to do a bit of digging around if you want to remove the presets however.
yes, it’s annoying because we have spent hundred of dollars in purchasing premium plugins and now if we uninstall it and we not longer use them then our money got waste?
