No plug-in starts and no error
Hello, when I want to use a plugin in Cubase or to use Grand Rhapsody Piano as stand-alone. There is a little time to wait and… nothing append.
I already :
  • use repair
  • use complete cleanup
  • use Fix permission and ownership
  • clear central cache
  • uninstall and install everything and delete wave folder in AppData / Roaming
    It was a time everyting works perfectly
I found the solution! Just need to re-install the Microsoft C++ redistribuable 2012
I have this exact same problem…the solutions doesnt work for me.
this works for me, re-installing the Microsoft C ++
tnks!!!
This just happened. No plugins would load in cubase. Ok one day, then wont load the next. Downloading Visual C++ Redistributable for Visual Studio 2012 Update 4 Worked.
Thanks Francois.
Hello @Francois ,
Seems you found the solution for multiple threads here :slight_smile:
You save my day…
John
You too hey?!? Not that I had the issue being a Mac user, but I have seen A LOT of these issues around the last 6 months.
Hello everyone, sorry to be late.
Happy that’s works for some of you.
For others do you have trying others solution in my first post?
For Mac : do software on Mac use similar dependencies ? On Windows the redistribuable are often used.
Why did you donwload the 2012 version of the c++ redistribuable? Why not the 2015/19 version?
Im on windows 10 and currently trying to fix this. I have seen there are 5 update for that 2012 version. Could you possibly send me a link to the one you used?
Thanks.
To let you know the reinstall worked for the wavesplugins as for my rane 72 mixer. Thank you!
I had problems with some others software. And they are more explicit than the plugins from Waves :joy: and which clearly asked for these redistributable. I am doing development with Unity, it may I delete by accident the redistributable. I take the first link I found
(sorry I am new on the forum so I can’t publish a link)
I reinstalled microsoft visual c++ redistributable 2012, also the 2015-19 version. Then after that I installed whatever I had previously installed while the c++ was currupt. including drivers. after that it all worked.
Hope that helps.
Hi All,
We are aware of such behavior with some Windows 10 systems and are working on a fix.
First, make sure to rescan your DAW for plug-ins according to our Rescan Articles.
If plug-ins are still missing, please reach out to our Support Team which will be able to provide a fix.
:slight_smile:
I have macosx…do you have any idea to resolve this problem?thanks in advance…
Instead of AppData/Roaming folder, try the Library > Application Support folder for both the system and the user.
To open the user Library hold down option and click on the Go menu in Finder.
