Temp Link should also link the plug-ins, or at least the emo plugins.
There needs to be a quicker way to set up custom layers.
RTA should be included by default in the EMO EQ.
Input B should be reserved for spare mics etc, not to be used for virtual soundcheck.
Other EQ/Dyn plugins should also show up in channels view.
It should be possible to move channels in regular channel view. You know, adding a second snare midtour..
Shift + tab to go backwards when naming channels in patch window.
Alt + click for default should also work when clicking on eq curve points.
Channel preset should apply to all channels in temp group.
User keys should be visible when in channel view.
Adjust scope settings on selected scenes, or all scenes.
When you touch a fader you should get an indication on the scope page of what channel number that is.
Fix so that we have instant scene change on recall.
Also: load user keys assignment from other session or globally save and recall user key presets
Make it possible to have custom layer setup part of a scene.
A separate direct out for virtual soundcheck with tap point pre mute, pre trim, pre pol switch.
The device to device is much to confusing cause that one seldom align with the inputlist.
Fix the metering, it does not make any sense at all!
Why does it clip at 0 and you have an extra +10dB of metering above that?
0dB should be like 24dB from clipping.
Ability to do patchchanges with snapshots, i.e. from mainvocal to sparevocal etc.
