I’ve been using Waves IR1 reverb with Finale for years. I know Finale is not officially supported, but with WaveShell version 14 it worked fine; I just added the VST3 directory that the WaveShell .vst3 and .dll files were installed in to Finale’s VST directories and it was able to load the plug-in.
I’ve just moved to a new computer, re-installed the same version of Finale, and installed Waves Central and IR1 on the new system (now WaveShell version 16.7). Finale is no longer able to find the plug-in, and I note that - unlike with version 14 - Waves has now installed only a .vst3 file, not a .dll file, in the VST3 directory. I suspect that the missing .dll file is why Finale can’t locate it.
Does anyone know whether there should be a WaveShell .dll file with version 16.7? If not, is there any way to downgrade back to version 14?
Note, I have contacted technical support about this, but have not yet gotten a clear answer as to whether there should be a .dll file and it’s missing, or whether WaveShell version 16 works differently and there simply is no .dll file…
