Waves 14 vst3 not working or found in plugin scanners
So in both FL and Ableton the vst3 waves 14 plugins arent found in both plugin scanners. In FL, the other waveshells are found and fine but particularly the vst3 one isnt found and its the one that uses all the plugins. — WaveShell1-VST3 14.12_x64 — this one is located in C/ProgramFiles/CommonFiles/VST3 and isnt found or stated as an error. anything for fixes? my licences are found and downloaded all redistributes and all that. thank you.
Hi @kindcollatz,
If you already went through performing a hard rescan and you mentioned fixing Windows redist’s files, id suggest to Contact Technical Support for quicker assistance with getting this solved.
I am having the same issues with Waves.
Question: how so I completely understand remove waves plugins from my computer -and possibly re-install these plugins?
Daw : FL Studio 24.
hi @nefu.steel
Completely uninstall: How to Uninstall Waves Products | Support - Waves Audio
Reinstall: Install & Activate Products | Support - Waves Audio
If you still experiecnce issues affer this, I suggest you Contact Technical Support directly.
Hi Yishai!
I followed all the steps listed; however, im still getting the wave shells error
I wonder, should I reinstall Fl Studio and repeat the whole waves installation process and see if that resolves the issue?
Hey @nefu.steel,
Please Contact one of our Technical Support representatives if you still require any assistance.
