Waves Artist DLLs is missing error. | FL Studio 2025
I have quite a few plugins from Waves, and most of them have errors. This started recently and suddenly. When I open the SSL EV2 Channel Stereo plugin, a dialog box appears (attached in the screenshot). with an error. When I open Vocal Bender, for example, I don’t see any dialog boxes at all, just the standard FL Studio window that says: “There was a problem opening the plugin WaveShell1-VST3 16.0_x64 for an unknown reason”.
I’ll tell you right away what I did:
  1. I completely reinstalled all of Waves. (I uninstalled everything and installed it again. I also cleaned the registry editor).
  2. I uninstalled and reinstalled FL Studio.
  3. I tried older versions of Waves.
  4. After each of these actions, I restarted my PC and in the Manage Plug-ins tab, I checked the boxes next to “Verify Plugins”, “Rescan previously verifed plugins”, “Rescan plugins with errors”, and ran the plugin scan. (Also, after any scan, I restarted the PC and went to check, but the error didn’t disappear). I also added the main Waves folder (C:\Program Files (x86)\Waves\Plug-Ins V16) to Manage Plugins and tried to scan it.
  5. I turned off all the antiviruses
By the way:
Waves version V16, the same plugins were downloaded, only version V15.
FL Studio 25, (I didn’t check on older versions, but it’s unlikely to make sense, I think it’s definitely not about the DAW).
Windows 10 Pro
Hey @lxstensxul,
Please Contact Technical Support and allow them to solve that for you, hopefully reducing your downtime and troubleshooting in the process.
Feel free to share your experience and solution to the issue in case it might help others.
