Subject:
Missing Globcon control when using Exbox.SG with LV1 Classic.
Proposed solution:
You can’t open Globcon on LV1 Classic, because you can’t install it - or have it running alongside the eMotion LV1 Classic software. I’ve been thinking about some solutions I’d like to share:
1: Change the Exbox.SG to have IPv4 open. That way one can open the Globcon GUI via an external browser for remote control (like the EXBOX.MD).
2: Change so that one of the four network ports is a dedicated control port and the remaining three are SG ports.
3: Access via the LV1 system inventory page, on the gear wheel; e.g. About, System Info, Clock, EARS…
4: DirectOut USB.MADI. Connecting an external computer via usb to the DirectOut USB.MADI for control.
The inconvenient solution at the time of writing:
At first I was trying to Share the Exbox from LV1 Classic to a secondary networked computer with SoundGrid Studio installed. Then assigned it to the external computer inventory, assign it to the MIDI driver of that computer (by committing ‘Assign to midi driver’), and run Globcon on the external computer to configure the EXBOX.
But this is not an option.
The ‘Assign to midi driver’ function is not available on a Shared unit. Only on the Main-host machine.
So the only alternative I have found is to have a secondary networked computer as Main-host for the Exbox, and have the Globcon control - And from there ‘Share’ the Exbox to the LV1 Classic.. But this solution has a number of complications that are not convenient…
For example; this external computer must always be connected in order to pass audio from Exbox to LV1 - and if it fails, you lose the entire audio stream from the Exbox.
And that the Exbox now must be the entire system’s Clock Master; because both LV1 and SoundGrid Studio requires a Clock Master, and the Exbox is the only common device.
All these ‘problems’ simply just to gain access to the Exbox control panel.
Thoughts:
My setup consists of LV1 Classic at FOH and Exbox.SG for playback on stage.
Mac Mini A and B run Ableton, and via SoundGrid Driver to Exbox.SG (EARS), and from Exbox.SG to LV1 Classic input.
I really believe this can become an extremely cool backing track solution. But at this point in time, with this knowledge I have now; Exbox.SG is probably not the best backing track solution for LV1. Either Exbox.MD (EARS) > Madi > Exbox.SG > LV1, or DirectOut Maven with a SG.IO network module would be preferable.. Or simply a modular LV1 setup, with Globcon access in the background.
