When trying to install Waves Central im getting “Central has encountered a system permissions issue.”
I’m in OSX Catalaina 10.15.7.
Any help would be higly appreciated !!!
Chris
Chris
Hi @cchipont and Welcome to Waves Forum
First please make sure that Waves Central was granted permissions in System Preferences > Security & Privacy > Privacy.
Check out the Accessibility and the Full Disk Access tabs in the list on the left. If Waves Central shows up in those lists - make sure to check-mark it.
In case the issue persists, feel free to contact our Tech Support department. They will be more than happy to get you up and running.
Dear @Gurik, and for all members, the issue was a mounted external disk. When dismounted, Waves Central could finally fix permissions and run properly.
Thanks @Urib for all the help in this matter.
Hey !
I was having the exact same problem, then I remembered that I had deactivated this helper one day (I don’t remember why)
I was getting the same exact error yesterday and today, and after hours of looking around files and registry keys, along with trying out different system permission schemes, I found a solution.
Firstly, it’s good to check C:\Users\user123\AppData\Roaming\Waves Audio\Waves Central\Logs\permissionFixer for the latest log, to see what the error was.
I have generally installed (almost) everything on my external SSD, which is formatted as an exFAT. I presume since exFAT doesn’t deal with permissions, the permissions attempt failed (even though Waves has access to the drive, as it has installed and created files there).
Nonetheless, I had to change my plugin folder from D:\Program Files (x86) to C:\Program Files (x86), to allow it to use my system’s default NTFS SSD drive.
To do this, I searched all over to place, but I did eventually find the file:
D:\Program Files\Waves Central\resources\res\external\data\prefix.yaml
In this file, near the begginning with the long list of value definitions, I added:
ProgramFiles(x86): C:\Program Files (x86)
This way, the symbol ProgramFiles(x86) refers to my ‘C’ drive, instead of my external drive.
So here is what the beginning of my prefix.yaml file looks like:
--- !define
--- !define_Mac
__environment__:
- HOME
NATIVE_INSTRUMENTS_SERVICE_CENTER_DIR: /Library/Application Support/Native Instruments/Service Center
USER_CACHE_DIR: $(HOME)/Library/Caches/Waves Audio
USER_WAVES_DIR: $(HOME)/Library/Application Support/Waves Audio
USER_LAUNCH_AGENTS_DIR: $(HOME)/Library/LaunchAgents
WAVESHELL_VST3_DIR: /Library/Audio/Plug-Ins/VST3
USER_LOGS_FOLDER: $(HOME)/Library/Logs/Waves Audio
--- !define_Win
__environment__:
- HOMEPATH
- CommonProgramW6432
- PUBLIC
- APPDATA
- CommonProgramFiles(x86)
- ProgramData
- ProgramFiles(x86)
USER_CACHE_DIR: $(APPDATA)\Waves Audio\Caches
USER_WAVES_DIR: $(APPDATA)\Waves Audio
Even though I put it after the --- !define_Win, you should be able to put it wherever the other variables are being set.
This is, in case, Waves Central is trying to access a drive that does not support permissions, like exFAT, which could be causing the permissions issue.
This was the cause of the problem for me. Reenabled it and all fixed.
