Hi… just got the Waves tune plugin. Sometimes it is scanning vocals incorrently and placing them in a totally different region to the rest of the vocals. The is causing those notes to glitch and pop. Any ideas how to fix this???
What DAW are you using??
This might happen if you’ve scanned, done you’re edits, but then later rearranged or move your audio around as Waves Tune isn’t yet ARA compatible. That’s if your DAW supports ARA in the first place.
Hi @john.d.bowker Thanks for joining our forum
This issue may also be related to tempo changes or a variety of use cases that we didn’t cover here.
I suggest you Contact Support in order to find out the root cause of this issue.
