After saving the Spherix compressor settings from Waves, after opening the saved project, the settings are reset to default. I observe the problem in users of almost all DAWs. I work in Fairlight Da Vinci, no methods help. I wrote down presets manually, but … alas. The settings are not saved. If anyone could suggest a solution, I would be grateful.
Hey @dmitr.drozdoff,
The issue you describe is typically associated with loading an unsupported format of the Waves plugins in your DAW, which causes all presets to reset to default when relaunching the saved session.
Using DaVinci Resolve 20, only the VST3 format is supported and is the only one that should be used when loading Waves plugins.
In case you are loading your Waves plugins as VST3 and still encounter the mentioned issue, please Contact Technical Support and allow them to investigate this further.
Feel free to share your solution experience.
