Vocal causing disortion/artifacts when using VocalDoubler/Auto-Tune
So my problem is that I have strange distortions, artifacts, something like distortion in the vocals. This happens with two types of plugins: autotune and vocal doubler. The problem appears with every version of autotune from Antares, Waves, and even Reatune (since I’m working in Reaper).
It also happens with the vocal doubler on both the right and left panning. I’ve checked these plugins on sends, tested them individually, meaning I had only the autotune or only the vocal doubler in the FX chain. I’ve checked the sample rate, tried different microphones, different interfaces, and even bought a new Mac Mini M4 512GB, but the problem still occurs on this new hardware. I wouldn’t blame it on the GPU; an important thing to note is that it also happens with acapella tracks from the internet or with other people’s vocals from other computers.
Below, I’ll attach samples on Google Drive so you can hear what it sounds like.
I would really appreciate help because I honestly don’t know what to do. I’m recording rap vocals, my own.
My setup is: RODE NT1-A, AUDIENT ID4 MK2, ATH-M50x headphones.
it’s definitely not any phasing or anything like that because it’s abnormal to have strange distortion in one of the headphones while using Auto-Tune, or to have weird artifacts in the vocals when there are pitch/tonal changes in Auto-Tune (the closer to the Note Transition 0.1, the more artifacts appear). Speed 0.1 or 8.0 doesn’t change it, but the note transition does. It’s not normal as most people would think that more extreme settings cause more artifacts, because my friend has exactly the same plugin, the same microphone, and doesn’t experience any of the artifacts I’m getting! For example, I’m using AutoTune Waves Real-time and Vocal Doubler by iZotope.
these are compatible with my system (Sequoia 15.3).
I really don’t know what to do – I’ve checked different XLR cables, thinking it might be the microphone, switched microphones, and still, it’s happening. I also tried a different interface – still the same! I really don’t know what to do, please help.
Well extreme settings are more likely to cause artefacts for sure. The quicker and faster something is set the more changes it is making per second that is generally how artefacts come about.
It’s usually not the equipment at all. Easing off the Note Transition and Speed should help to reduce artefacts.
The other part of it is the source material that youre using. If it’s too sibilant, the pitch is way off, there’s too much vibrato (wobble) in the voice, or too many outside voices interfering or you have denser/dereverb taking too much away then they are also going to cause issues with trying to pitch tune a track.
So addressing the “performance” quality of the track is also something that will help fix these issues. You may need to do what the pros do and lay down multiple passes, and edit together the best bits before processing them.
