Greetings Waves team,
No, I’ve tried it and coundn’t find any vst3 plugins. (0 plugins scanned),
I tried this step, but still the same issue,
https://www.waves.com/support/how-to-scan-non-waves-vst3-plugins-in-studiorack
may I have anyone to help me
kind regards,
I have the same exact problem they showed up before updating studiorack and now they won’t show up
Hi @7usainarab @alvarog19948,
When scanning Non-Waves VST3 plugins it is essential to verify the following
- The non-Waves VST3 is supported with your OS version.
- An active license for your non-Waves VST3 plugin is active on your system.
- Your DAW version is supported by Studiorack V14
- The non-Waves VST3 shows up in your VST3 DAW.
- You can try and perform a hard rescan from your DAW(you will be able to find easy step-by-step guides for each DAW we support by simply typing the DAW name you wish to obtain instructions for, in the Waves search bar on Waves.com.
If you are still not able to get it to work after verifying all the above I am sure our Tech Team will be able to take this if it is Waves related.
Have a great week.
I just downloaded studio rack for free but in waves central it is not showing any activation sign?
Hi @nikhilbadshah77,
You can try following the steps in the next article.
If you’re still unable to load Studiorack within your DAW feel free to Contact Technical Support for further assistance.
