Hey I would love if we could have multiple VST 3 saved like for your lead one Hot space button and you have the 2,3,4 VST always open at the same spot you previously had them that way you can jump from every rack fast and see you PSE, EQ & Comp all at once and then can jump in one clic to your MAIN LR ans see your 3,4 VST layout in a sec and jump back and forth between key racks.
On MAC the IN of the plug in is right under the closing tab of the pop up window could you move it so the fat finger dummies like me would stop disabling plugins mid show?
Also can you make the Waves plugins sizable?? on a small screen the PSE is small AF…
Also is SRP fully optimized for MacBook Pro M4 Pro??? I feel I can load Reaper with plugs and nothing happens before lots more tracks are added while I had cracks after 8 racks with a couple 0 latency plugs running and 2 reverbs. The performance of the Mac seems to be following what reaper asks it to do while I hear crask with SRP before I even hit 20% CPU
