I’ve been absolutely loving 3rd party support on Performer the only clunky part of the workflow has to do with the behavior of opening a 3rd party plugin compared to opening a waves plugin. Much like opening a plugin on a daw, a third-party plugin in Performer will open as a pop-out window. While this isn’t a big deal, the issue arises when i’ve got a mix of plugins on hot keys and when I open another plugin the previous 3rd party plugin pop-up doesn’t auto close so i’m constantly having to close windows. I know other daws like Pro-Tools have options that allow the plugin pop-up windows auto switch / auto close / limit to one pop-up plugin at a time. Curious if this is in a hidden menu somewhere or if the Waves devs could add this as a feature.
This would be very much appreciated since right now its basically impossible to operate vst plugins with a touch screen. Closing the old windows with a tiny button each time i want to select another plugin ist way to time consuming.
Pls just make it possible to auto-close the previous plugin oder give the user an option to set the maximum of open plugins by themselves.
Yes! This would be amazing. It works this way in basically every DAW so I can’t imagine it would be that difficult to do in SuperRack.
Ideally, I’d love to see plugins appear within the native window (rather than a pop up) but if it has to be a pop up window, at LEAST, make it where the previous plugin closes when you open a new one or switch to a different channel.
Right now it makes the GUI so had to use when it gets covered by plugin windows.
+1 on this. i am LOVING superrack alongside my M32, and the use of midi control makes things so fast and easy EXCEPT… when dealing with 3rd party vst gui’s. i’m totally fine not being able to map to them, as i use waves plugs for most of my heavy lifting, but it is a pain that not even command-W from my laptop keyboard can close the window.
please consider this request, waves. you are batting .990 otherwise
<3
Is there any update on this? This is the one thing that’s really holding back my workflow within SuperRack. It’s so frustrating having to close out of all these windows individually.
Ideally I’d love to see 3rd party plugins open within the main SiperRack GUI (like Waves plugins do) but I understand it’s difficult to know how 3rd party plugins would need to be resized.
If we can’t have them open within the main window, then we at least need the option to close all the windows and to have the previous plugin window close when a new one opens so that all the windows don’t stack on top of each other.
