Just got a soundgrid server, and love it. However, there is a peculiar problem I’m having trouble with.
When I record vocals, if I use the server for low-latency monitoring, the vocal signal seems to sound weird and almost “doubled”… at first I thought maybe I was getting a lot of room reflections but then I did another take without the server and it goes away.
Any thoughts? I’m not double patching or anything. All soundgrid studio channels are muted and not even patched.
If you still can’t manage to fix it, We’ll need some more details in order to assist with it;
Which DAW are you using?
Which SoundGrid application are you using? (Version 9/10/11?)
Are you also using a SoundGrid I/O?
Which OS is your computer running on? (i.e Win 10/Mac OS 10.14.6)
In any case, I would strongly suggest contacting our Tech Support, to further look into this and assist you in the best way.
