Please remove the artificial limitation with Magma Springs 3 Decay steps. The long Decay is unusable and i need more options between Short and Medium, since Medium generally is too long and Short is not long enough sometimes. The echo build-up is too much in long and medium. The short settings is extremely beautiful and a couple settings after it would serve the plugin well. Also maybe a ‘Shorter’ setting before the Short.
Soundtoys recently released a plugin called SuperPlate Wich has a feature called Auto-Decay that you may want to copy. Auto-Decay reduces the build-up in long Reverb Decays. Magma Springs is a Masterpiece, and i bought it instantly. Congradulations on such a great plugin! You’ve created something special here, don’t mess it up with a too severe limitation that has only 1 highly usable decay step!
