IR-L Virtual Acoustics Presets not showing up
After having downloaded the IR-L Presets and placed the folder according to the indications from Waves, only the Sampled acoustics V2 presets show up in the application.
The other folder (virtual acoustics) does not show up when loading IR-L.
I can “import” the .wir samples using windows explorer but it is a more tedious process.
Any advice would be appreciated.
Hi @SmokeyJoe,
Please contact Waves Tech Support about this, I am sure they can sort it out for you.
Already did but no reply so far. That’s why I tried this as well.
I see you are in correspondence already. Let us know how it pans out!
I also encountered the same problem. The IR pulse library plug-in of Virtual Acoustics does not display at all.[quote=“SmokeyJoe, post:1, topic:892, full:true”]
[/quote]
Hi guys, did you solve that problem? I have the same one and wanna figure it out.
Hi @apaclin,
If you still need any help Technical Support would be able to assist and can hopefully save you time and effort.
Please let us know how it went.
