hi, I have a problem with the plugin, when I use the side chain I always find myself with a delay of 20ms on the side chained track. only if I use the live version I don’t have this problem.
how can i solve it?
Hi, @FRANCESCONI1988
When using the regular inphase plugin component as opposed to the Live one, you will indeed be obtaining some latency as opposed to 0 latency when using the Live plugin component.
Exact Lanecy values for both plugin components can be found here
Have a great day ahead.
InPhase introduces has a 20ms of latency just so it can provides us with +/- 20ms of time adjustment to aid with the aligning of fades. It can indeed play timing havoc in some cases.
Have you tried setting Logic’s Plugin Delay Compensation to “All”??
