I’m using a Soundcard, Soundblaster X AE-5 ASIO and I can’t have more than 1 of the programs running. I’m using the Program TracksLive to record, and then a Program from Waves for the MIDI keyboard I want to play. If I try to open TracksLive and set my System Settings to my soundcard, it says that the device is not working properly and will switch back to None when I have the other program open. It’s very frustrating and I need this fixed so I can start making some music!!!
Hi Culisome,
It seems like you are using Windows, and the SoundBlaster’s Audio Driver for Windows does not ‘Multi-Client’ compatible (meaning, it cannot be assigned to more than one application and has to remain ‘exclusive’ to 1 app).
Tracks Live is really supported for use in SoundGrid scenarios (where Waves SoundGrid hardware serves as the Audio I/O)…
Let’s try and re-think this:
If I understand correctly, you want to:
- Launch a Waves Stand-alone instrument (like Bass Slapper, or Flow Motion synth)
- Record the result to a WAV file
In order to achieve this,
I’d recommend launching the Waves Virtual Instrument within a DAW/Music Application -
That way, you can launch a Virtual Instrument, record the MIDI notes, and export to WAV (or record it within said DAW/Music Application to a new Channel, and ‘mess’ with it)…
Here’s a list of Fully Supported and Qualified DAW’s to run Waves plug-ins at the moment.
