Everytime I use H-reverb the right output channel is considerable louder than the left. Every instance of the plugin in every project. It does not happen to any other plugin I’m using. I would love some help to understand why och how to fix this.
Much love.
Hey @oliver What DAW version and OS are you working on? This info may help us identify the issue.
You are also welcome to contact support directly to look in to this issue.
Well. I was just stupid. Was using the mono/stereo plugin with stereo input sent to it. I was reading the name as if this version made it possible to switch between mono and stereo. Right plugin for the right channel config solved the problem.
