H-Delay Ping Pong Issue
I am currently using H-Delay version 12.0 on Ableton Live 10. The issue I am experiencing is with the Ping Pong delay feature. As soon as I enable the Ping Pong delay feature, the left channel is very noticeably a couple of decibels louder than the right channel. At first I believed it to be an issue with panning, but as soon as I disable Ping Pong the levels from both L/R even out. I have tried troubleshooting and did everything from messing with all the settings to testing it on multiple projects, types of audio, mono and stereo signals, and swapping the Stereo for the Mono>Stereo version of the plugin. I have checked all the meters throughout the troubleshooting process on both the plugin and the DAW and the Ping Pong delay causes the audio of each channel to bounce up and down (as it should), but the left channel is always higher than the right channel.
My workaround is to use the Utility Tool, place it after the delay, and pan right to compensate; but that can prove to be very tedious.
Its possible due to the fact that delays decay in level over time. So the first side to get the signal will receive it the loudest, before it starts decaying.
Although, there is a slight chance it might have something to do with what “pan laws” you have chosen for your DAW. I believe its the “compensated” laws that boost left and right by 3 to 6dB. But that should really affect both sides equally.
It does not affect both sides equally. it makes me wonder if something is wrong with the algorithm and not user error. have you tried it yourself?
Yes, I use it all the time. Though, as I have said delays decay in nature. SO of course the first repeat to the first side will be louder, the second repeat will be softer and on the other side, the third repeat softer again. That’s just the nature of delays and ping-pong.
Play Ping Pong Outdoor On a variety of tables. Check Ping Pong Outdoor tables here.
Um yeah, that’s not the kind of ping pong we’re talking about here. Marketing is not permitted here.
Careful, the security might show the door. :wink:
I just got the H-Delay and wanting to use the Ping-Pong feature. When I engage the plug-in, the first delay is always in the left channel. Is there a way to have the first delay in the right channel?
Have you tried messing with those øL and øR buttons?? I can’t remember what they do now, but it might work
i have the same problem, the right channel have more db than the left, if I star the ping pong on the right I can ear only this one, I don’t know how to resolve
How is the original sound, is it centred balance or is it leaning more two one side. If so that may have something to do with it. In which case you can always balance your signal a bit before it hits the delay.
You can also try messing with the øL and øR buttons.
Phase adjustments are unlikely to help (unless there’s some serious interference going on), but panning the L and R back towards the middle after the plugin is about the only way I’ve found to be able to use this mode (S1 Imager is an easy option). Generally I just avoid the ping pong mode, and go to SuperTap (or in my DAW, Comeback Kid) when I want any kind of stereo.
Yes, the original sound is centered balanced, and only with the Ping pong mode i have this problem, as i wrote befere i ear the repetitions in the right much loud than the left
Perhaps it’s an actual bug. Might be worth reporting.
