First, it’s annoying how if I add my entire sound library folder, it doesn’t break it up into subfolders. There are times due to licensing issues, that I have to avoid looking in certain folders. I want certain folders excluded from my search and the only way is to be able to toggle those folders off. The only current solution is to manually add each individual folder (which also doesn’t show those subfolders either). We can’t even see the structure! This is baffling and makes me wonder if the programmers of Cosmos even use it themselves
The other annoying thing is when you click the + button to add folders, you literally can not select more than one folder at a time. You can only select ONE FOLDER AT A TIME. If you have a ton of packs, it’s soooo slow and inefficient.
Next we can’t do any type of sorting other than based on name, length by bars, key and BPM. WHY. This also makes no sense. Not all of us use this for music, why can we have length in seconds instead of bars?
Also we can only see the filename and not which folder it belongs to. Seeing just the filename isn’t always helpful, sometimes I need to see which subfolder it originally belonged to.
I bought Cosmos because it looked clean and the performance features seemed nice. But I’m stuck with a program I don’t love and already having buyer’s remorse because it can’t do simple things it should
