Clarity Vx dropping audio in Davinci Resolve
Hi! I noticed that when I add in clarity vx to an audio track that there is an intermittent drop in audio. Does anyone else have this issue? Need some guidance on how to troubleshoot or fix it. Wave form looks fine and if I remove clarity vx from the track the audio plays back fine. When its added in, it drops at the exact same places so I don’t think its a performance issue with the hardware. Thank you!
Hi @matt4,
What’s the sample rate and buffer size within that session you’re working on?
Have you tried raising your buffer settings to 1024 for instance?
You can Contact Technical Support directly for assistance to get a quicker response and diagnosis.
Is it in trial mode?? Or does that do like a noise burst thing, or something different??
Do the drops happen with each cut, is it consistently timed or is it more of a random thing??
yes after install and uninstall still the same not working on davinci 19
Hey @crystalxme1,
If you’re still experiencing issues using your Waves products please consider Contacting our Technical Support team.
