Anyone here running Waves on older version of Cubase?
Hi there!
Anyone still running an older version of Cubase here and having trouble with newer versions of waves plugins?
My Cubase 6 wont recognize V13, V14 and V15 Waves plugin versions… The plugins are “successfully” installed, vst3’s are in correct folder, but they don’t appear in Cubase plugin list. Versions V10, V11, V12 work fine.
I reinstalled visual c++ all versions, as this could be one of the potential problems… Running win 10 here, using offline installers as workstation is not connected to web.
Anyone had similar problem and managed to solve the problem?
The solution would be much much appreciated.
Thank you and
Best regards!
32bit / 64bit maybe ?
This thread also deals with a similar issue: Waves plugins not recognised by Cubase after upgrade to V13
Hi there!
Thanx Dagroch for your reply.
Cubase, C++, Waves… all 64 bit…
I have read the thread you’ve linked, not a problem with the profile name…just normal letters…
Version V13 introduced window sizing option… Does this feature need some special windows
drivers or anything?
Some more ideas, anyone?
Thanx,
Regards!
Update: Version V10, V11, V12 are recognized by Cubase, V12.7, V13 etc are not…
What has changed in version V12.7 and later versions vs V12?
Thanx,
regards.
