Accidentally installed SD samples
While installing all my waves plugins, I accidentally installed the SD version of the samples.
Is it possible to still install the HD variant?
And how?
Do I simply select Horizon again only and then select HD next to it and click install? Even though I’ve already installed horizon? Just to have the HD samples also?
Same with cosmos?
Hi @atticmike,
No harm done, you can use the next link to redownload any Sample Library manually from our website.
No need to redownload the Horizon bundle again.
Note that this is only for Waves Sample based Instrument, if you wish to download Cosmos related library, you can do it from Waves Central.
You can also change the destination of the samples within Central’s settings. Additionally, if you relocate them at a later date you can run up the plugins and point them to the new location.
