I’m just getting started with Waves SR Performer for some simple adjustments. First on USB, but thinking about buying the Wing Compact internal WSG Card.
My question, since I’m routing some of the audio via the PC I also use for Waves SR Performer is: Can I route my PC audio directly into a channel on the Waves SR Performer?
Now the only way it seems to work is Jack-Out to a Physical Channel on the Wing, which is sent to Waves SR Performer over USB and then Back to the Wing over USB.
I cannot send audio over the same USB using the Wing Driver when also have Waves SR Performer engaged. I figured there must be a way to route the PC audio as a direct insert in Waves SR Performer, but i cannot seem to find it.
