(Windows 11 Pro)
Waves Central was only able to activate my licenses when I run it as admin (with the help of the support). Otherwise there is no target device for activation (also no USB stick). Waves Central does not see any disc or USB-Stick when run as a normal user. (Although as a main user I am a member of the administrators).
In programs like Steinberg Nuendo, the plugins are only available if I start everything as admin. Even if I start Waves Central normally as a user, the licenses are not activated (target device missing).
(Apparently Waves has no rights to recognize my hard drives.)
Now both PCs are affected by the phenomenon. Even a fresh installation of Windows does not change this problem. However, Steinberg Nuendo does not work properly with admin rights.
Is there any solution to this weird problem?
