I have utilized every step of the way shown on how to install all this stuff. No matter what I do the VST does not populate in any of my Ableton VST folders. I don’t know what to do at this point
Hey Quictrackstudios, welcome to the Waves Forum.
I think a hard rescan of the VST3 which is the only supported format using Waves and Ableton might do the trick here, you can try the following.
Also in case, you have a Custom VST folder set you can set it with Waves by performing the mentioned steps.
If those fail for some reason, our lovely support team will be able to get you U&R quickly.
