I just loaded the latest version of Clarity Vx (downloaded yesterday) into the latest PC version of Adobe Premiere 25.2.3 (Build 4) and although it appears where it always does as an option in the Effects tab, and I can drop it into the audio track, the effect never appears on the Effects Control tab. It’s just not being applied that I can see. Tried to reinstall and restart, but nothing works. Recommendations?
Hey @flotsamjetsam,
I suggest Contacting our Technical Support team.
They should be able to fix this quickly. if you insert the plugin and nothing happens, it is also sometimes related to Microsoft redistributable files missing or corrupt.
From memory the default setting does not process at all. You would most likely need to open the plugin window, possibly from the mixer, and manually set the controls there.
Zero issues having the plugin seen. Check. Zero issue having it in the effects menu. Check. When I drag it into the audio track nothing appears at all in the applied control panel–it is NOT there. It always appears there on every other system I have loaded it on, this is not my first install. It is loaded, it shows up, but it is not being applied to the audio track for me to open it and do anything-and the little waves logo is not showing up
Maybe it needs to be applied via the mixer. It does induce a lot of latency, and there maybe no latency compensation on the audio region… If I’m understanding what you are telling us correctly.
Otherwise, you can always do what Adi suggested above and getting on to their Tech Support. They should have a clear idea of what’s going on and how to fix it. They’re usually quite good.
Feel free to share your experience and solution to the issue.
Having similar issues on Avid MediaComposer…any fix?
Hey @AusMart,
Avid Media Composer is not a supported host; we tested and qualified to work with Waves products. You can find the list of supported hosts in this link.
