“Waves Central could not have initialised properly and will be closed”
A message that poups up when i try to open Waves Central.
I use windows 7 64 bit and latest version of waves. This issue/error is nowhere to be found on forums and pages. I tried do use older version,wave central 10 which supports win 7,but when i try to login it says something like “waves servers not available”…and also i have to install the older version without internet connection,otherwise it will update itself with a new version which again,does not work. HELP?!
HI @milosmatic489,
To run Waves on Windows 7, I suggest going over the following information, this should guide you through installing and activating the licenses from a supported computer onto a USB flash drive.
Hope that helps, have a great day.
