I develop a hardware controller to control the vstfx. a touch screen allows you to automatically insert the plugin in the desired slot. the plugin then goes into edit mode and can be edited by the controller.
preset 1 will be dedicated to shape and gate. preset 1 will be dedicated to compressors and limiters.
the order of the presets does not determine the order of insertion. a plugin is inserted in less than 500ms. about 6 times faster than your mouse.
the current serigraphy will be reviewed and corrected to be universal. management is thought of as a console strip. the touch screen can also choose for certain plugin the send return mode. the effect track is then created automatically. I will post here tomorrow the list of parameters for each type of shape / gate / compressor plugin. if your plugin has an additional parameter within the limit of accessible functions it will be implemented. the preset should be automatically recalled. if you insert a compressor
the compressor edit preset will be automatically loaded. the preset selection buttons are only used in the event of parameter re-editing in the future. Unfortunately, no cubase function allows you to inform the hardware controller of the type of plugin edited to date. only reversing it is possible. I await your remarks and suggestion. for info the controller will work in midi cc midi nrpn note off / on … I wanted to add 6 motorized faders zvec an arduino but I do not know this type of card and have not found an electronics engineer capable of doing this for me … if an electronics engineer wishes to participate. the controller will have 8 infinite potentiometer. and 8 fully configurable switch. if we add the 6 faders this will make 14 +8 … it’s up to you
