Unexpected CPU spikes
I’ve been noticing occasional CPU spikes on my M2 Mac mini when running several Waves plugins together. It’s not happening all the time, but I notice it more when I have a few plugins active in the same session.
The overall CPU usage doesn’t always look particularly high, so I’m trying to figure out what’s causing the spikes. Has anyone else run into something similar? Is there a good way to identify which plugin or background process is responsible?
I know that Logic has a Pre-Process Cycle option, that will process the start of the cycle a little bit ahead in time for a smoother looping experience. Features like that can cause temporary spikes, but that’s by design.
What DAW and OS on and how much RAM & SSD capacity do you have?? These can also factor into CPU spikes.
Hi @eri-Skylar,
Thanks for sharing. That kind of spike is tough to pin down without seeing the session, so please open a support case, and they can go through your setup/session with you.
Let us know how you go too. It’s often helpful to hear back about people’s problem resolution with Support. It can often help others with similar issues as well.
