Studiorack Crashing Ableton Live 11.2
I’m having problems, gems and StudioRack crash Ableton Live 11.2, I insert it into the channel and a few seconds later Ableton just closes.
I’m using StudioRack V14, Ableton Live 11.2
Windows 11 Home version 22H2
Hi @regizsandes,
Please Contact Technical Support, they will be able to provide you with precise instructions to solve the issue after a quick diagnosis.
Generally, such crashes can be caused when using an unsupported format when loading Waves in Ableton instead of using VST3 which is the only one that’s supported.
Another option since you are on a Windows OS, might be related to broken/damaged Microsoft C ++ Redistubatble that might cause crashes among other issues.
Already updated C++
same issue continue =(
Anyone can help me?
I tried Technical Support, no answer…
Tech Support sent you a reply yesterday and requested more info so please check your spam box or junk mail in case you do not see the email.
Updating the redists is different from repairing them so that probably won’t do the trick if you just updated them.
