SoundGrid to multiple computers
I will have a Wing Console with SoundGrid card to create the SoundGrid network. Is it possible to connect 2 computers to the SoundGrid network (using network switches) and pick up the audio (unprocessed) from the Wing Console to route into a DAW - like how a Dante network would work. Is this possible with SoundGrid?
Hi @go2richie,
Yes, this is possible.
To create this setup, you will first need a SoundGrid application (SuperRack SoundGrid/eMotion LV1) to manage the network, there, in the inventory page, you assign your I/O devices - for example, Wing IO, DAW computer #1 and DAW computer #2. Then, create the patches in the Patch > Device to device section (Wing > DAW computer 1 & Wing > DAW computer 2).
This is a very simplified explanation - a lot depends on the SoundGrid application you use and the specific use case.
If you email support and explain what you’re aiming for, I’m sure they’ll be able to assist with every detail down the road.
In any case, Waves does have this article that explains how to add recording/playback computers to a SoundGrid network - How to Add a Recording/Playback Computer to a SoundGrid Network | Support - Waves Audio.
