When working on high-resolution DAW projects, a server overload is expected at some point that causes audio performance problems. WSG activity will occasionally spike above 100% while mostly remaining in the recommended 70 to 80% range.
FEATURE REQUEST: For each plugin loaded in SG mode, the usage percentage could be provided by hovering over or clicking into one of the following areas:
- The WSG meter of SoundGrid Studio
- Server on the Setup tab of SoundGrid Studio
- Each plugin loaded in StudioRack
This would speed up troubleshooting and boost productivity when faced with server overload issues that can drain time from the creative process.
Thanks!
