SoundGrid Server One-C X10 does not lock domain (blinking red LED) on macOS 15.3 / Apple Silicon M4
Hello Everyone! Im pretty new to the whole SoundGrid/Server/Performer World, I recently purchased a SoundGrid Server One-C X10 & I’m requesting assistance with a SoundGrid connectivity issue that I’ve thoroughly troubleshot and would like some assistance if possible.
System Overview
•	Server: Waves SoundGrid Server One-C X10
•	Host Application: Waves SuperRack Performer (latest v15)
•	Computer: Mac mini with Apple Silicon M4
•	OS: macOS 15.3 (Sequoia)
•	Network: Originally Via Network Switch, as well as Direct Ethernet connection (Cat5e) from Mac onboard Ethernet to server
•	Console: Behringer WING (also tested without console connected)
Issue
The Server One-C X10 Network LED remains blinking red and never joins a SoundGrid domain (never turns green), even when SuperRack Performer is running and the SoundGrid Driver is selected and active.
What I Have Confirmed / Tested
•	SoundGrid Driver is installed, repaired, and selectable
•	Driver Control Panel allows selection of the correct NIC (en0)
•	macOS assigns correct link-local IP (169.254.x.x)
•	SuperRack Performer launches correctly and claims the SoundGrid driver
•	All Waves components are installed via Waves Central (latest)
•	Permissions and security approvals are complete
•	Tested with:
•	Direct Mac ⇄ Server connection
•	Netgear GS108 switch removed from chain
•	Reinstalled SoundGrid components and repaired via Waves Central
•	Rebooted with correct power-up order
•	Server behaves normally when no Ethernet is connected (red LED expected)
Despite all of the above, the server never receives SoundGrid clock/domain lock and remains blinking red.
Question
Is there a known issue or limitation with SoundGrid DSP server domain lock on macOS 15.x (Sequoia), specifically on Apple Silicon M4 systems, even though SuperRack and SoundGrid are listed as compatible?
Additionally:
•	Is there any firmware dependency or update required for the Server One-C X10 in this scenario?
•	Are there internal builds, beta drivers, or recommended workarounds for macOS 15 + M4 at this time?
Hey @jimmyflawless,
Our Support has already replied to your email.
Feel free to share your experience and information; it might help others in the future.
Hi, I am having same issues. Can you share your Solution?
Hi @ayo114,
One of our Live Sound team representatives will be contacting you soon via email.
Feel free to share how it went.
