Silk Vocal: Why is the HP not linear phase in Studio Mode? Shortcuts
As above
I usually use eg an Ozone for HP as after extensive testing and the vocal in acoustic cases benefiting from ultimate transparency on every level, why is the HP not linear phase in Silk? in keeping with the rest of the filters?
The HP should also corroborate the male/female choice as pretty much there is no female fundamental below 120hz and male below 80 (although there is eg Geoff Castellucci but unlikely you are doing a lot of work for the likes of ‘Song Of Durin’)…?
Just a small one…why is there no shortcut to apply mouse moves to all filters at the same time?
eg Once I have a general adjustment in place, it would be convenient to hold qualifier and move 1 dial to move all 3 vs wet dry ie maintaining a visual feedback when learning the plug
As a guess, most likely it’s so that Silk Vocal can be used live.
Linear Phase algorithms introduce too much latency to be able to use them live. Ozone clearly wasn’t made to be used live so iZotope has bit more freedom in how they design their filters.
It’s to do with the mathematics involved. It needs to look at values “ahead of time” to be able to do the necessary calculations. That translates to extra latency.
Yep…totally get that…but they have a live version separately. The filter they are using absolutely mangles the phase
Oh yeah, I totally forgot about the live version, thanks for pointing it out.
So yeah, to do a 180 and almost contradict myself hear, but you know, they could have added a linear phase filter, at least as a choice.
I will add though, I don’t often use linear phase filters. Not that I don’t like them, it stems from years of writing and tracking into a computer, adding some processing as I go, but also trying to not to add to latency as I build the track. So by default linear phase eqs were just someone. I never thought about alot, despite having a couple.
The trick I find with working with non-linear phase eqs, commonly known as minimal phase, is to not park the filter where it “looks” like it should go, but where it “sounds” like it should go. Not to confuse this wth an annoying and unhelpful “use your ears” passive aggressive statement.
What I actually mean is that because of it being not linear phase, where you place the filter or a crossover in a a multiband compressor, is obviously going to do a bit of shaping to that sound.
So you just take advantage of that aspect and park it in place where it’s actually helping to carve out some unwanted frequencies, in the case of a crossover. In the case of a LPF I’m placing it where it 's removing enough of the unwanted frequencies, but isn’t having a negative impact on the fundamental. That is unless I think the fundamental does need a bit of toning down, in which case I place it higher.
This all regardless of what the visualiser looks like. After all, the visualiser isn’t the thing that people will be listening to. It’s there as a guide and really shouldn’t be treated like gospel.
Sure…I agree its not what it looks like but in context, its the cumulative effect and phase is generally about the combination of elements as well as the focused solo. Often have vocals here from live recordings in the stereo and whilst I can usually manage bleed with f8 mics eg r84/92 I dont need to guess that a HP will be needed.
Anyway over the last year, esp getting client jobs, I have taken a diff route and stop the complexities by offline processing HP (linear phase) basic loudness and eq and baking it all in with tape and soft limiting. This forces me to commit, simplifies the mix in orders of magnitude and finally feels how mixing use to ie tape does most of the deal that we all chase now, harmonics, soft limiting etc
I still use SV as a live plug but its not really important anymore in the above context
Great chatting!
PS I cant fault the Ozone eq and generally I only use Linear Phase for filtering as mentioned, there is no degradation of any kind when used like this…well…measurable or audible that I can tell…thats confidence
Yeah I get what you are doing there. Since it’s also just light cleanup work it makes sense to commit it and save the CPU.
I, on the other hand, try to do t all in the DAW so everything can be changed or done if needed. But I commit and save the CPU by freezing the tracks. It’s especially useful if I get feedback notes telling me to change what otherwise couldn’t be changed after committing. Well not without incurring extra artefacts to the audio.
But thats a process I found worked best for me.
I use to do that a lot; all of the workflows get a bit sticky I guess (for any baking really). I was only really trying to get it all back to the same playing field in terms of the feel on tape…not necessarily beyond that. I find that is a decent compromise but pretty much mix is getting so much simpler for me these days esp, with clean up parked in the pre mix workflow. I think settling into a confident monitoring situation (mainly these concrete “perspective” spherical low level monitors kind of like the best of ns10/auratones) and a quick reference makes the whole thing a lot faster and less fatiguing as well as a lot more about feeling it that getting distracted in details. Do that for prob 60% of time, 30% polishing the supporting <100 and >10k then final loud listens on ATC…I do notice now, with such a foundational mid range approach, Im not really rebalancing just polishing after that.
It is a journey though and keeps developing for us all…all the best for Christmas!
BTW love to hear some of your mixes? Mine are so different atm; this current project on hold till feb but Ill put some links up and give it a critique if you want :slight_smile:
Merry Christmas too bro.
