Server One (original) Power Issues
Hello, has anyone experienced a server stuck in power cycle?..my server one (original) won’t power up and its now stuck in power cycle. Powers up for a few seconds and powers down and repeats. SuperRacks won’t see it.
Hi @mrsoundtech,
I suggest Contacting Technical Support to save the time and trouble they will be able to remote in to your setup and assist.
I am also having this issue, it happened while I was on tour
This happened to me summer 2023 after a trip to Israel - server worked fine there and had the same issues you reported once I got back. It ended up being a broken power supply. I got a new one on amazon, and it worked fine, until it blew again a couple weeks ago. I’m thinking of leaving the waves hardware eco system as the waves system updates always require a prayer before performing for fear that something will break. Unfortunately, some of these updates are mandatory, leaving a path of digital uncertainty. I’ve already had to rework several projects where I used SuperRack because the server broke and waves update made the problem worse. I’ve also had UAD accelerators as long as I’ve had Waves Server with no issues with any version updates.
Would love to know where you got with this? I’m currently suffering the same issue :weary_face:
Hey guys my fix was to replace the power supply and the RAM memory. Ive been solid since then, im still using my Server One without a glitch.
Great! Thanks @mrsoundtech. Was thinking of going down that route and now definitely will :+1:
One more question @mrsoundtech ….. where did you get the power supply from?
I bought the power supply on Amazon, just make sure when buying the power supply and specially the RAM memory that its a match to you what your server uses.
Does anyone have a link to the Amazon replacement power supply?
ARESGAME AGV Series 500W Power Supply
for some reason Im not allowed to post a link. but the name above is what I purchased in 2023 when I repaired mine.
