I am new to this world, so I googled and used ai to know about it and been reading and watching many articles and videos about having a good voice for solo podcast, or solo voiceover, or solo audio on video.
I will be doing everything in my bedroom, and I want to produce a professional audio as possible, if possible.
I’ve made the special place at the corner of my room and added the blankets all over the place, and no echo could be heard now except a few.
I was at the shop to order the microphone, and the guy in the shop (just regular customer I guess and not a staff) started to talk about how expensive hardware could be replaced with software to some extend, and during his conversation he mentioned waves, at first I thought he means waves of the audio in the audacity so I said the name, and he was really kind to clear the differences and explained the waves software it is something you add to the audacity or anything else, and he mentioned many other software that i do not even recognize except audacity and audition.
then he advised me as a new user to do not buy expensive microphone or expensive hardware because the audience who will listen will not distinguished the differences in the beginning and I am not professional yet.
then he advised to buy the audio technical microphone and buy the waves plug in instead of other hardware.
when i went back home and searched and found your website, I found dozens of software that really get me lost and confused.
so now, does what this gentleman said was accurate about using the software?
and if answer is yes, so which software exactly to get.
I did googled this a lot with ai once again but found many saying about the collisions or contradictions or redundancy between software plugins, so I thought to post in the forum as for sure someone faced the same situation and found a good solution.
so from scratch point till I finish, what plugin or set of plugins I need to do solo podcast, or solo voiceover or solo audio on video?
I hope if anyone may make things clear for me like:
For step #1 use plugin titled xyz.
for #2 use xyz.
…etc
Does what I thinking about or imagine is doable or I get the wrong picture completely?
i hope that i posted in the right forum section and sorry if i bothered you with any details but thought to share the full situation to let you see the exact situation.
thanks
