QRec goes yellow
hi, I’m using QRec to connect my laptop and X32 mixer, no SGS, just a direct connection
I have MBA M1 running MainStage and use a lowest network buffer setting (104 smp)
I’m pretty happy with latency, it’s much faster than Dante (104 / 48 = 2.17 ms vs 4 ms with DVS), but channel number “32” near the button “OUT” in QRec goes yellow pretty often and may produce settle clicks, couple times it even went red and produced dropouts
next setting of 288 smp buffer solves the problem but it’s a 288 / 48 = 6 ms which is okay for MainStage, but not for inserts like LP for example
I have a Satechi and TPLink dongles, tried them with SGS & LV1 host application, they worked totally fine, thinking about Apple TB3 → TB2 → Ethernet chain of dongles, maybe Realtek chips inside Satechi and TPLink is a problem
CPU load is low, nothing suspicious, two different OS (Monterey and Sonoma), tried both clock settings (Internal on X32 + Digital on DN32 and Exp.Card on X32 + Internal on DN32)
maybe somebody had this problem, I’d be glad if you share your thoughts!
made a screenshot when it happened, but no links allowed
Hey @Inside,
One of our Live Sound representatives will reach out via email to further assist with the behaviour you described.
Feel free to share your experience and solution.
Hi I‘ve got the same Issue. Setup: Waves Card, C1500, Supperrack Performer, mac studio with sonoma. I do run qrec with rosetta, since then it just turns yellow but no dropout occurs. still, i don‘t trust it 100% to. what can I do?
Hey @treyerp,
You can Contact our Live Sound Support team, who will be able to remotely connect to your setup and ensure everything is set up correctly. You can also go over your setup over the phone or via email if a remote session is inconvinent
I´ve got the same problem using QRec on Windows on the highest buffersize with a DM0 with Waves Card, have you found a solution?
Hey @jockl,
One of our Tech Support representatives will follow up via email to further assist.
Feel free to share your experience and solution once you’re U&R.
