Hope all is well, I need some pointers? I need to do a live stream with a talk and there will also be videos with music. I want to make the audio on the stream the best. I’m using vMix and want to add VST. I looking at the NS1 but I need some extra? What will you recommend I add? L4 multi master?
MV2 → use the “broadcast wizard” preset, keeps your talk level consistent
Dan Dougan → keeps your crosstalk consistent (so background noise won’t alter if 1 or 4 microphones are open), also helps you to keep focus on the person actually speaking
Playback Rider → keep videos and music in the correct loudness range
WLM Plus → monitor and limit to correct level/loudness of your stream
