Ovox wet output
Hello there.
I’m playing a little bit with ovox plugin to try having a talk box effect on a recorded voice.
That sounds perfect but there is a small issue (i’m probably missing some configuration buttons), i’m still hearing the original voice recorded.
Is there a button to only have the final treatment, like a dry/wet general mix button ???
For the record, i’m using Cubase and i put the plugin as an insert to an audio track
Thanks !
Hey @lerdouille2,
Since you’re using OVox as an insert, make sure the track’s input monitoring is off.
If the issue persists after verifying the above, please Contact Technical Support for further assistance.
