New Product ! Studioverse Instruments / Audio Effects
StudioVerse Instruments
Dreamy keys. Synth basses. EDM leads. Play thousands of chains from layered instruments, MIDI FX & audio FX.
New! StudioVerse Instruments
StudioVerse Audio Effects Revamped!
StudioRack redesigned. Optimized search engine, tags, suggested presets, and a streamlined UX.
New! StudioVerse Audio Effects
Learn more
Is there a known issues list for studioverse windows
Or list of vst3 not scanning, kontakt and many others ?
Same here, re-scanned the VST3s several times, from within Reaper and Studio One, it comes up with the same VST3 list all the time, missing a lot of the ones that are installed on my PC.
When I add sounds, share them as public, they are not shown in studioverse search?
Is there an additionally step nessesay to share them? please
Can we hide Chains for which we dont own the used plugins, please?
Hi @anon77818099
StudioVerse does not support publishing instrument chains that use samples outside the Waves Audio Factory Pack (installed with COSMOS).
If that’s not the case and you’re still unable to see your content publicly please Contact Technical Support for further assistance.
I guess it’s not just for universal compatibility reasons, but I’m sure to ensure all samples used have copyright clearance. The last thing you would want is users posting patches with song tips, that could pose a legal nightmare.
Some synths aren’t compatible to stack because they have more inputs & outputs…
If i want to stack the virus ti or kontakt, it isn’t possible as these have too many inputs & outputs…
Can it not just use the 0 input 2 output structure it needs and move on, instead of completely disabling the use of the plugin.
How else would we use Kontakt inside this plugin?
Hi it doent even work with just one audio waves plugin for me.
see my other post (i am not allwed to post links here …)
Hi @anon77818099,
Please Contact Technical Support to get further technical assistance.
This sounds amazing thanks for sharing these insights mate as I found it very much useful and informative to be honest
Any word on if this plugin will allow plugins like Kontakt which have a different number of input/outputs…
Have you guys made sure that it’s the VST3 version of Kontakt you have installed??
Obvious question, I know. Though you be surprised how many can overlook a simple thing like that.
Yeah running vst3 obviously as its the only plugin format this works with.
It’s not about that though, it’s the rules implemented for the amount of input & outputs from a synth as far as i understand.
Anything that has multi out, is not recognized or usable, hence the virus ti and kontakt for example are not at all usable inside studioverse
Ah!! This is not the first time I’ve heard this actually. My money is on the fact that I think Waves will respond to this feedback and work on adding support for multichannel plugins.
Here’s hoping.
@csoljan @simon.a.billington
We are currently investigating issues where Kontakt is not being scanned by StudioVerse and are working on a fix.
Check out the new trial bundle for StudioVerse!
