New Plugin! Curves Equator.
Perfect balance. Zero resonance. Your mix, unmasked.
Smarter Resonance Suppression & Frequency Unmasking
Massively improve full mixes, vocals, instruments or samples with automatic removal of problematic frequencies and balancing of inconsistencies.
Additionally, ‘Learn’ your content and get a personalized suppression curve to safeguard your work and never overprocess. Even ‘Learn’ via sidechain from a clashing source and apply the inverse curve – statically or dynamically – for perfect carving and frequency unmasking. Learn more.
Get it Now
Curves Equator is also available in the Waves Ultimate subscription, and has been added to the Mercury bundle.
Diplo
(Beyoncé, Justin Bieber, Dua Lipa)
“I love Equator! The Learn feature has been so important in getting my mixes better every time.”
Bryan Anzel
(Future, Juice WRLD, Lil Uzi Vert)
“WOW! This is the ultimate cheat code. If this plugin can’t get you to finally mix like a pro, I’m not sure what will!!”
Joe Chiccarelli
(The Strokes, U2, Beck)
“Curves Equator is the perfect tool for getting rid of those harsh midrange frequencies in a vocal that often make it difficult to sit in a mix.”
Hear it in Action
Will there be a live version for the LV1 mixer?
Hey @gbolahan.onamusi,
It is currently available in all hosts we support and SuperRack Performer, not LV1.
Thank @Adi.Waves. Do you have any plans for LV1 e.g a lite version due to latency?
FINALLY!! I don’t actually own Soothe so I’ve been kind of hoping that Waves will fill that void with something similar that I can get as part of the subscription!!
Party time!!
Wow, wow, wow, and wow. I own at least 4 products that compete with this one… but Curves Equator has become my preferred over all of them!!!
The UI/UX is amazing — it can be used in a simple way, if you prefer, or you can dig into the advanced controls and have a lot of control over exactly what it’s doing. Really well done.
And the SOUND is amazing! I love “delta” listening to what these plugins do, and what I discovered is I can use Curves Equator in a way that doesn’t have a lot of artifacts. I love that.
I was starting to move away from this type of product, but this one can be so subtle yet effective that it’s perfect. (Or it can be extreme if you dial it that way!)
I know Waves was late to the market in making this type of product, but I’m GLAD they waited because they really did an excellent job. Congratulations, Waves team. This tool pushes the genre forward.
(Now all I need is for Waves to add loudness measurements & TruePeak to ALL their limiters!)
That is a problem with Soothe. Well, I think it’s more of a user issue to be honest. every time I see someone use it they always end up removing so much that I can hear all that fuzzy style artefacting. Every time.
I’m not saying Soothe is a terrible tool, quite the opposite, I think it’s extremely helpful involving alot of problems. I just think the users need to take it more easy with it.
Working on FL? Tutorial or anything
Hey,
Yes, it is supported with FL.
Here is something to get you started
I tried to use side chain feature but plugin is not reciving sidechain signal.. Is there any tutorial how to set it up?
@manjeetkujur351
If you enabled the SC\Learn option and are still unable to receive a signal, I’d suggest to Contact our Technical Support team.They will be able to guide you through the process ensuring everything is set up correctly.
Curves Equator has a sister plugin now… Curves AQ!! Wow!!
