Curves AQ / Equator / IDX dynamics
Hello
I would like to know if these plugins are meant to be placed on single synth tracks, synth buses or the master track?
Thanks in advance for your help
Hi @andrzejc,
Welcome to the forum.
All three of those plugins are flexible enough to use anywhere in the chain, so the right spot really comes down to what you’re trying to achieve in that particular mix. Placing one on an individual synth track lets you shape or unmask that specific sound, while running it on a bus or the master helps address masking and buildup once several synth layers are combined. It’s worth trying both a track and a bus version to hear which gives you the result you want, and if you’d like input on your specific session setup you’re welcome to contact our support team for personalized help.
Curves Equator will help you get rid of any resonances or mud or any frequencies clashing with another track. You just need to set up the sidechain to listen to a clashing track to be able to automatically do the latter. It’s good for “cleaning up” a track before enhancing it. As such, it’s often good to put before Curves AQ.
AQ, itself, is designed to help you enhance a sound a dial in a good “tone” that compliments the track. It will listen to your instrument or voice and provide you with a few “ideal” eq curves to start with, but then you can go deeper and continue to shape the sound further yourself. So you’re not stuck with some kind of preset sound.
IDX will help with levelling the dynamics so the soft and louder parts are more consistent. It can help sounds to be heard more consistently or it can help control them so they can sit in the background under other sounds.
It works pretty simply and intelligently, but isn’t the kind of compressor you would use to help “shape” the sound, such as enhancing the attack. But you could always use Smack Attack or another transient enhancer to help with that.
I have Curves Equator then IDX on my Master bus. I have them both reducing around 1 to 3dB across all frequencies. The difference between having them off and on is night and day. Highly recommended. Before them i have TDR Slick EQ M which is a 6 band eq but its super power is that you can widen/narrow the stereo image on all 6 bands, my default is to have everything from about 1K upwards nice and wide with a gentle Q slope. Before this i use Slate Digitals VTM which adds lovely Tape machine tones. Lastly i have a Waves L2 as the final limiter to get -0.1 as the finished level. So thats VTM into TDR Slick EQ M into Waves Curves EQU into Waves IDX into Waves L2. There might be better master bus chains out there but i love this.
Glad you found a solution that suits you and I’m so glad it hasn’t fallen into the stereo type “I always use SSSL Buss Compressor on my mix”.
I always think it’s better when people explore and discover their own solutions that work for them rather than simply do something because the saw Chris Lorde Alge or Andrew Scheps do it, no disrespect to them.
That said, we always have room to improve and it’s often great to learn from those more experienced and wiser than us. But there is a difference between following wisdom and following a religion.
